Multifunction DAQ
Is it possible to Meet an Increment Condition and then Decrement within the same While Loop?
I noticed that the "Equal?" function requires a boolean as an output but say you want to continue by decrementing 10 down to -10 V.
Is there a way to achieve decrementing after incrementing within the same while loop?
Many Thanks
(2,412 Views)
Maintain your state and counts in shift registers and you can decide whether to add or subtract the 10.
GCentral
(2,389 Views)
Accepted by topic author neunited
The indexing array input is a bad idea with your while loop 🙂
AND  unless you exactly now all values of the DBL it's also a bad idea to compare two DBLs with an EQUAL ... better use a >= or <=  or for this case the IN RANGE
Greetings from Germany
Henrik
LV since v3.1
(2,337 Views)
