Installation NiDAQ Driver onto Knoppix 3.3
Hello List,
I have trying to install my NiDAQ Ni-3036E onto Knoppix v3.3, it is a debian variant. I tried to install NiDAQ API Driver from NI.com/linux.
I began to install that driver using :
$ ./INSTALL
after I agree with license agreement,
an error message occurs :
"error: cannot open package index using db3 - No such file or directory (2)"
./INSTALL: line 280: [: 1: unary operator exepected]
How to resolve that problem so that I can install NIDAQ Api driver onto my Knoppix ?
For any help, Thank you.
Susanto W
(2,746 Views)
Hello Susanto,
It looks like you are running into some difficulties with the driver installation on a Linux machine, so that you can use your PCI-6036E device.
The driver that you would need to use would be the NI-DAQmx Base Driver 1.5.
Unfortunately in the readme I don't see that Knoppix 3.3 is officially supported by the driver (only Mandriva (formerly Mandrakelinux) 10.0 Official, SUSE LINUX Professional 9.2, and Red Hat Enterprise Linux WS 3).
You could try working with the NI Measurement Hardware DDK (Driver Development Kit).
If any other users out there have more information about the specifics for Knoppix then please share your knowledge.
(2,733 Views)
Thank you for your answer Mr. Otis.
Finally, I changed my Knoppix3.3 with Mandrake 9.0 and that driver successfully installed without error.
I have a project to make an application using Kylix to control the speed of motor using NI-3036E. The speed is proportional with the analog output from NI-3036E. Can I use that driver with Kylix 3 Enterprise beside using C++ language ?
Thank you for any answer.
Best Regards,
Susanto W
(2,722 Views)
Best Regards,
Susanto W
(2,723 Views)
Susanto,
Great to see that you got everything installed!
I've never used Kylix 3 Enterprise, but as long as you are able to access the various DLL calls to the daqmx dlls with Kylix then you should be able to use that program.
I do not think any official testing has been done with Kylix so I cannot guarantee that it works though.
Matt Otis
(2,706 Views)
