04-12-2022 02:10 PM
I have a NI USB-6218 BNC DAQ unit. Input voltage range is +/-10V. I want to collect data from six Bently-Nevada proximity probes with a linear output range of -1 to -17V. What is the best way to condition this signal? Bias the common ground or set up a voltage divider? Are there better ways?
Thanks in advance.
04-12-2022 04:43 PM
Biasing the common ground works if the proximity sensor has a floating output. Voltage divider would be the easiest option provided the output impedance of the probes are good and your choice of resistances for the divider doesn't load the signal.
04-13-2022 03:00 PM
I'm going to try using some in-line attenuators. I have some 20dB and 6dB. Hopefully the 6dB will get me in range. If not I go to the 20dB. We'll see how this goes.
04-13-2022 03:06 PM
Do note that these attenuators load the signal from the sensor, ensure that this loading is not significant or you will get inaccurate measurements.
04-20-2022 04:25 AM
insert a 9V batterie?
OK, while this would work, the voltage stability of such a source migth not be the best 😉 adding a 7-8V low drop voltage stabilizer would do the job.
So one stable voltage source and a OP amp per channel to add the voltage ( and another for an input buffer)
04-20-2022 06:47 AM
Mr. Volkers - Thank you for your response. I am now planning on building a signal conditioning box using op amps to amplify (or attenuate) and bias these vibration signals.
04-27-2022 11:51 AM
