I am running a little python script to log the data from a microphone, I would like to sample a sine wave with 500Hz, so I thought I would need a sampling rate of 10000. I can log some data but it seems I am not activating IEPE from python.
This is the code I am using:
# import libraries
import time as t
import numpy as np
import nidaqmx
import csv
fSampling = 10000 #Hz
nSamples = 1 #samples
dtMax = 10 #sec
csvfile ="./data.csv"
# DAQ
# config
with open(csvfile, "w") as output, nidaqmx.Task() as task:
writer = csv.writer(output, delimiter=';')
task.ai_channels.add_ai_voltage_chan("cDAQ1Mod1/ai0")
task.timing.cfg_samp_clk_timing(fSampling)
t1 = t.time()
dt = 0
while dt < dtMax:
data = task.read(number_of_samples_per_channel=nSamples)
t2 = t.time()
dt = t2-t1
writer.writerow(data)
it is mostly copied from different sources but I think I get what it does. I read in the nidaqmx-python documentation that I can set the IEPE sensitivity, but I couldnt find anything about how to enable it at all.
The setup works with labview:
Any ideas how I can get this to work with python? At the moment I am mostly getting Noise with python and a good signal with LabView.
EDIT: The DAQs I am using are:
- NI cDAQ-9171
- NI 9250
kind regards,
Johannes
