07-20-2006 05:53 PM
07-20-2006 11:33 PM
07-21-2006 12:29 AM
There are three types of terminal. One is RES(Referenced Single-Ended Configuration), another is DIFF(Differential Mode) and NRSE(No Referenced Sigle-Ended Configuration). Before connect the wires, making sure which's kind of your sensors.Judging from what you told, the temperature sensor maybe 3-wires RTD or Thermister. Both temperature sensor and presure sensor have SGND terminal. So the tyep of the terminal is RES.You need connect Vout to AI+, SGND to GND and V+ to Power Supply+.Only the type of DIFF need connecting Vout+ to AI+ and Vout- to AI-.
07-21-2006 12:59 PM
07-21-2006 01:34 PM
