From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Multifunction DAQ
How to simultaneously Read scope 0 and scope 1 of elvis ii?
Dear all:
  I am a user of LabVIEW 2010. Recently, I have downloaded the lockin start up kit. I want to use ELVIS for the signal input. I want to input the data signal and reference signal using scope 0 and 1. But in the front panel of the demo lockin program, I only can assign 1 scope for input. I have see the back panel of the program, the signal from the DAQmx is 2d array. Therefore, all scope should be assigned. How I can assign both scopesHo in front panel?
(3,831 Views)
Hi nieekfbm,
Unfortunately the lock-in startup kit is not officially supported by NI anymore but I'm hopeful that the forum users will be able to relate to your question. Are you able to post a screenshot of the interface and where your issue is occuring?
David H.
(3,800 Views)
I find that elvis is support the simultaneously reading of scope 0 and scope 1
Thank
(3,789 Views)
