From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
How to Empty Data Buffer
Good morning all,
I am trying to empty my DAQ buffer (while my VI is in 'pause mode' etc). My buffer size is set to 100,000 (I think) and the number of samples easily exceeds this (90kS/s). The problem is that once the 100kS is exceeded, the number of data in the buffer goes to 0, and so any read VIs with -1 as the number of samples doesnt read out any data, but when i resume my VI it has to trawl through millions of pieces of data before it gets to the most recent ones, and back to Real Time operation.
Any ideas?
- Capuchin
(2,832 Views)
If you might be paused long enough for the DAQ hardware to overrun the buffer size, you won't be able to use the (-1) option to read "all available samples" anymore.  Your Read call should be returning an error when you make an attempt to do this -- are you handling it?
It sounds like what you really care about is more like "most recent samples" and there's a way to get those directly.  Under LV, there's a DAQmx Read property node where you can set "RelativeTo" = "Most Recent Sample" and "Offset" = -N, and then request N samples.
-Kevin P.
(2,826 Views)
Hmm, I solved the problem programatically by altering the buffer size to 30,000,000, giving me 5 minutes of save dialog before it will break. I realise this is a fairly crude solution. If it proves to be too crude, i will keep your idea in mind Kevin, Although it will need slight alteration of the timings, thanks.
(2,805 Views)
