09-27-2010 06:51 PM
I can set the analog output and read the analog inputs, Is there anyway to read what voltage is set to an Analog output with out setting it?
09-28-2010 12:13 PM
Can you re-phrase the question? That's like me asking if I can read my reply to this post without replying to it.
09-28-2010 12:39 PM
I'm just trying to see if there is a way to query what voltage was set to an analog output. I want set it in one vi, but read what was set in a different vi. I just want to know if there is a way I can query what voltage the channel was set to previously (without creating a global variable when I originally set the output), Does this make sense?
Thanks for you help.
09-28-2010 02:36 PM
What device are you using? Most multifunction boards have an internal channel for AO vs ground. On an M Series board, for example, you can read Dev1/_ao0_vs_aognd in an AI task. When you create your channel constant/control in LabVIEW, right click on it and select "I/O Name Filtering...". Make sure that "Internal Channels" is selected.
09-28-2010 02:52 PM
I thought there might be a DAQmx property that could provide this but I don't see any way to do it. In any case, it seems as you're going to have to at least pass a DAQmx reference to your subVI to do this (even with Mark's solution) so why not just pass the last value you wrote to the channel instead?
