Multifunction DAQ
How can I connect PC and Ethernet DAQ?
I want to connect PC and Ethernet DAQ (NI 9239 + NI cDAQ-9181)
But, NI DAQmx cannot find and add them
it connect to my pc by ethernet cable directly
IP Address is auto setting
My PC OS is Windows 7(+ visual studio 2013), so i tried NI-DAQmx version 19.5 to 20.1
but dose not work...
please help me
sorry about my english skill
(827 Views)
Without a DHCP server, then the cDAQ is will likely use a default IP address.  You will need to make sure your Ethernet port works with that same subnet as the cDAQ.  This is one of the reasons I prefer to use fixed IP addresses.  A quick solution for you may be to simple router, which have built in DHCP servers, to connect between your cDAQ and PC.
GCentral
(818 Views)
