Multifunction DAQ
Hardware Error 50152 PCIe Windows10 NIDAQ 19
I have one program working fine for 2 or 3 months, and now I recieve the -50152 randomly.
I have reinstall the NIDAQ drivers.
I have change the PCIe slot.
Even I have purchase another DAQ, which has been working fine for more than one month, and now I have the same error message.
In order to run the program again I must reboot the computer but it doesn´t guarantee that the error will be gone.
I would apreciatte any help as there is not much informatio about this error. If you need any extra information please feel free to ask.
Message 1 of 8
(1,037 Views)
Try the steps in Error -50152: "A Hardware Failure Has Occurred"
Control Lead | Intelline Inc
Message 2 of 8
(1,013 Views)
Hi ZyOng,
Thank you for the help, I already followed these steps with the first DAQ.
Reset NI MAX Configuration -> It worked for a couple of days and then the error came back.
Didn´t install the BIOS Compatibility Software as I don´t use PXI.
Change PCIe slot -> same error after a couple of reboots.
Verify other cards ...  -> Bought a new DAQ, it was working fine for some weeks until yesterday.
I am not usind any Thrunderbold MXI Expansion so I didn´t follow those steps.
I thought it was a DAQ problem but now I realize it is not, and now I don´t know what to do.
Message 3 of 8
(1,004 Views)
What's the versions of Windows, NI-DAQmx driver and LabVIEW?
Message 4 of 8
(999 Views)
Windows 10
NIDAQ 19.1.0f2
LabVIEW 2012
Message 5 of 8
(994 Views)
LabVIEW 2012 is not compatible with Win10.
The first supported LabVIEW version in Win10 is 2015 SP1. NI Product Compatibility for Microsoft Windows 10
Message 6 of 8
(982 Views)
Thank you for the informacion, I wasn´t aware of that. I have some old exes running under windows 10 that were developed in XP and I did suppose that it wasn´t a problem.
Good to know thank you
Message 7 of 8
(978 Views)
Hello again,
It looks like there was some kind of incompatibility with an Yottamaster PCI-E to USB3.2 expansion card. One we removed the card the problem dissapeard.
Message 8 of 8
(865 Views)
