From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Multifunction DAQ
Generating a TTL Pulse
I am trying to use an NI-6259 to generate a TTL pulse that will be sent to three cameras in order to sync them into capturing video at the same time. How do I go about doing this?
(946 Views)
Accepted by topic author SoppierBrute9
See shipping example <LabVIEW>\examples\DAQmx\Digital Output\Digital - Finite Output.vi
Control Lead | Intelline Inc
(938 Views)
Can you send me a link to this example I can't seem to find it and want to make sure I am reading the correct example. Thank you for the help.
(934 Views)
LabVIEW menu >> Help >> Find Examples... >>
(896 Views)
For a single start-trigger-style pulse, a Digital Output example will be just fine.
But if you need a continuous clock (i.e., a pulse *train*) for each camera frame, I'd recommend starting with the Counter Output examples.  (You could also use a counter task to generate a single triggering pulse, but there wouldn't necessarily be any advantage over a Digital task.)
-Kevin P
(877 Views)
