02-23-2018 01:12 PM
Hello to all,
I am trying to read the signals of two microphones using the signal of one of the microphones as a trigger. But I having trouble to set the trigger properly. I made a VI using examples I found in internet, but the error -200077 keeps showing up. I could not understand what could be the problem, but I am sure it should be very simple to solve
The measurements work fine if I by-pass the trigger. (the Case. Structure in the VI)
My VI is attached below.
I am using a NI 9234 board and LabVIEW 2015
Thank you all in advance
Frederico Araujo
Solved! Go to Solution.
03-01-2018 12:48 PM
Hello Frederico,
I took some time to study your program and I believe I found some things to help you.
Hope it helps you out.
