Digital waveform generation with DAQCard-6036E
Is it possible generate digital waveform (via one DIO line) 10 kHz with DAQCard-6036E? If not. What card you can recommend?
Deniss Karai
(2,437 Views)
Deniss,
No, you cannot perform hardware-timed digital output through any of the DIO lines. However, you can generate a continuous pulse train at 10 kHz using one of the 6036's counter/timers, and the output will be TTL-logic compatible. If this will work for you, you can find shipping examples for generating pulse trains with the counter/timers.
-Kevin P.
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(2,426 Views)
