09-13-2009 10:51 AM
Hey guys
I have a DC fan that works between 3 and 10 volts and needs 1A. I need to control it using a daq 6009 by varying the output voltage at the analog output of the daq. i am well aware that the daq cannot give the necessary current that the fan need, so i need a power stage that isolatesthe daq and the fan so i dont damage the daq.
can anyone give me some ideas of what should i use to give the current i need to use the fan?
thanks!
09-14-2009 06:12 PM
Hi!
It sounds to me like you'll want to use a voltage follower that you can connect your USB 2009 and your external power supply. From what you've explained, you'll need an external power supply- you can learn about power supplies that we sell here. What kind of current are you looking to source?
