08-04-2010 08:18 PM
I'm trying to use the DAQ diagnostic utility 2.0 to test my PCI 6010 card. The device shows up properly in MAX, and there it passes the self-test and self-calibration. When I run the utility, though, after passing device support, NI DAQmx Version 8.6, device reset, and giving the last self-calibration date, it says error -200197 occurred at Property Node DAQmx Device (Arg 3) in Get Device Param. vi->Diagnostic Utility SubVi.vi->Diagnostic Utility.vi. In the report it says "Error: the selected device does not support a property needed to run this utility." What should I try now?
Thanks, Myra
08-05-2010 04:24 PM
Hi Myra,
What operating system are you using? Do you have the LabVIEW 8.0 Run-Time engine installed? What behavior is your card exhibiting to necessitate the testing of the device?
To use the DAQ Diagnostic Utility, you need the following:
08-05-2010 05:38 PM
Yes, I have met all of those requirements... I did try Version 1.0 of the utility just in case there was some sort of problem with NI DAQmx, but it got stuck at the same point as 2.0 did. Although I am using DAQmx 8.6 (which should be fine as far as the diagnostic utility goes), I decided to update the drivers and am in the process of doing so now. Could that be the problem?
Thanks, Myra
08-06-2010 09:37 AM
Hi Myra,
The PCI-6010 is a B Series device which is actually unsupported by the DAQ Diagnostic Utility. The error you are seeing is expected, and happens for any version of the utility and for any PCI-6010. Since it sounds like your card is working correctly despite using the utility, I would not worry about the results given by the Diagnostic Utility.
08-06-2010 04:09 PM
In the Readme file for the diagnostic there is a list of supported devices and the PCI-6010 is included in that list... Is that inaccurate?
Thanks, Myra
08-09-2010 05:08 PM
Hi Myra,
Corrective Action Request (CAR) 145329 has already been filed to address an issue with PCI-6010 not working with this version of the DAQ Diagnostic Utility. Hopefully this will be fixed with a future release of the utility. Can you please elaborate on the need to use the utility? I can offer troubleshooting assistance with more information about the overall issue.
