05-06-2014 04:32 AM
Hello there!
I would like to use the USB-6259 to generate two independent PWM signals using the two counters of the device and send them to two of the four available anolog outputs. Additionially I would like to use the third AO to generate a variable DC output.
Now I would just like to now if I have to fear any creeping currents that might destroy me PWM signal or if everything should be fine doing it this way?
Thanks in advance,
Kamil
05-12-2014 02:29 AM
Hallo Kamil,
here is Dominik from the AE's in Munich.
Which USB 6259 device do you use. Can you give me the full marking?
Dominik
05-12-2014 07:56 AM
Hi Dominik,
it's the modul 779628-04 with the two connectors which you can see in the 6th picture of the other views.
There is also a small update on the signal output:
Of course I won't use the AO for the PWM signal but instead I will simply send the counter outputs to two PFIs, thus the only AO will be the one for the set point of the PID-controller.
Additionally there will be now an AI from a massflow counter which has a range of 4 - 20 mA.
Kind regards,
Kamil
05-20-2014 06:51 AM
Hi Kamil,
The AI is oparated with 5 - 10V. The maximum voltage and currents which are allowed are described in the specifications of your target.
Attached i send you a tutorial for generating PWM with LabVIEW. Perhaps it would be better when you use the national instruments examples in LabVIEW. You can find it under Help-> Find example.
Pherhaps it would be better when you send your programmed code when you have problems.
Best regards
Dominik
