12-23-2005 12:59 PM
12-27-2005 04:06 PM
Dear Eric,
It sounds like you want to do a continuous analog output that does not rewrite old data. If this is the case, use the property DAQmxSetWriteRegenMode set to DAQmx_Val_DoNotAllowRegen before your timing function. Then write your data in a while loop. With this method the buffer is handled for you. Have a great day!
Sincerely,
Marni S.
01-04-2006 02:07 PM
01-04-2006 02:37 PM
01-04-2006 03:35 PM
