Connecting a pH probe (from Hamilton) to the NI-9208
Dear all,
I am trying to connect an Hamilton pH probe to the NI-9208 module.
The pH probe is connected to a transmitter (Arc Wi 2G Adapter BT)  and the wiring diagram is this one:
So, I have done the connection like that:
Arc 2G Wifi
NI9208
1
AI0
2
COM
3
AI1
4
COM
7 and 8 are connected to a 24VDC
But it is not workin.... What did I do wrong?
Thanks a lot!!!!
(904 Views)
Accepted by Iforire
As per your transmitter it needs a power source for the 4-20mA channels.
You must connect as per this diagram (NI-9208 will be your PCS),
Arc 2G Wifi
NI9208
1
+24V
2
AI0
3
+24V
4
AI1
Santhosh
Soliton Technologies
(893 Views)
Thanks a lot Santosh, I'm quite a beginner in all that 🙂
Actually, that's the first thing I've tried, but it seems I did it wrong.
Also I need to connect the COM of the NI-9208 to the GND of the power source, right?
Thank you
(889 Views)
Yes, all three - sensor, transmitter and NI-9208 must share the same GND i.e., COM.
Depending on wiring constraints, this also works,
Arc 2G Wifi
NI9208
1
VSUP
2
AI0
3
VSUP
4
AI1
+24V
VSUP
GND
COM
Santhosh
(877 Views)
Dear all,
That's me again since I have some problem in connecting a Brooks Mass Flow Controller to the same NI-9208 and a NI-9266 for AO.
Please find below the connections for the MFC.
Here is what I did:
MFC Card Connection
1 NI-9266 COM0
4 NI-9208 AI1
5   +
7 NI-9266 AO0
9   -
10 NI-9208 COM-17
Is this right?
Or should I connect as for the Hamilton probes like that (as COM-17 is already connected to '-')?
MFC Card Connection
1 NI-9266 COM0
4 NI-9208 +
5   +
7 NI-9266 AO0
9   COM-17
10 NI-9208 AI-1
Connecting this stuff is definitely not my forte 😉
Thanks a lot,
Iforire
(398 Views)
@Iforire wrote:
Dear all,
Here is what I did:
MFC Card Connection
1 NI-9266 COM0
4 NI-9208 AI1
5   +
7 NI-9266 AO0
9   -
10 NI-9208 COM-17
Is this right?
MFC Card Connection
1 NI-9266 COM0
4 NI-9208 +
5   +
7 NI-9266 AO0
9   COM-17
10 NI-9208 AI-1
Thanks a lot,
Iforire
Please create a new topic so it is easy to find in future.
Santhosh
(392 Views)
