Ni.com is currently experiencing issues that may cause some pages to fail.
Support teams are actively working on the resolution.
Can not connect the Ni USB-6259 correctly
WHey everyone,
I am facing a problem with using Ni USB-6259. When I connect it, the LabVIEW DAQ or DAQ assistant cannot recognize it. Even in  NI Max, it can not be connected.  It looks like below, I have only one USB-6259, but shows two in the NI MAX, and both are not useable. In the past, it works fine for an analog signal acquiring, but after a colleague used it in Python environment for digital counting, it can not be used in my setup anymore. Does anyone know how to solve the problem? Thanks a lot!
(2,329 Views)
Hi Dewen99,
might be a MAX database corruption.
See here to reset the database: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8awSAC
If this does not help, have a look at these troubleshooting steps: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7OaSAK
(2,235 Views)
