Cable to NI-6143. Same as for PCI-6024E?
I am using a PCI-6024E with cable 184949C-01 (68 pins) and a connector-block CB-68PL. I have some problems with sampling speed with 6024E. Therefor I am considering buying a pre-used NI-6143 that has simulatiously sampling of the Analogue channels.
Question: Does the cable/connector I already have fits the NI-6143?
Both cards are PCI...
Regards
(2,221 Views)
Accepted by Haddock01
I'm answering myself.
No, you need a NI SHC68-C68-D4.
(2,141 Views)
Just for future reference, you can check the compatibility between the DAQ device, cable, and terminal block below.
http://www.ni.com/product-documentation/53080/en/
(2,123 Views)
