08-13-2019 05:37 AM
I am using a PCI-6024E with cable 184949C-01 (68 pins) and a connector-block CB-68PL. I have some problems with sampling speed with 6024E. Therefor I am considering buying a pre-used NI-6143 that has simulatiously sampling of the Analogue channels.
Question: Does the cable/connector I already have fits the NI-6143?
Both cards are PCI...
Regards
Solved! Go to Solution.
08-13-2019 03:05 PM
I'm answering myself.
No, you need a NI SHC68-C68-D4.
08-14-2019 02:31 AM
Just for future reference, you can check the compatibility between the DAQ device, cable, and terminal block below.
