07-07-2022 01:22 AM
Hi
I have procured CDAQ 9189 and 9266 AO modules. 9266 is detected and self test is OK. It is allowing to write to the module from test panel also, but no output is visible at the 9266 terminal. what might be the issue.
07-07-2022 11:15 AM
That module outputs current, not voltage, and requires an external power supply, have you read the manual and wired up the external supply?
-AK2DM
07-08-2022 12:07 AM
Thanks for the reply. Yes I was missing the external supply. It is resolved.
