06-03-2014 10:17 PM
I encountered something that i think a bug in MAX.
connected to cDAQ, and the when i run the self test on the main (on the hostname) it shows that the self test is successful.
but when i run the self test individually, i found out that 1 of the module is damaged and need to be repaired.
why the error has not appeared when run the self test at the hostname at the fist place?
It's a bug.
06-05-2014 01:33 PM
Hi Toyan,
When you run self-test on the cDAQ chassis, DAQmx only tests communication between your computer and the chassis. This is the intended behaviour.
You could write a little VI that self-tests a chassis and all the modules in it. With a DAQmx Device Property Node, there is a property called Chassis.ModuleDeviceNames that will give you an array of modules. You could index through the array and self test each of them.
-Luke
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
