BNC (sensors outputs) to pin (inputs of DAQ) connectors
Dear
I would like to ask about the type of the BNC (sensors outputs) to pin (inputs of DAQ) connectors that can work for the below items.
I want to connect the PCB Low noise coaxial cable (10 ft w/10-32 plug to BNC plug;  SN: HC9019377) to  DAQ (USB-6003 16-Bit 100 kS/s ; SN: HC8146386  )
I searched your web-site and found BNC-2120 Terminal Block.
https://www.ni.com/en-lb/support/model.bnc-2120.html
BNC-2120 - NI
68-Pin Female SCSI to Female BNC and Screw Terminal, DIN Rail, Desktop Mount, Shielded Terminal Block—The BNC-2120 can be used with various NI multifunction I/O and analog output devices.The BNC-2120 simplifies the connection of analog signals, some digital signals, and two user-defined connections to the data acquisition device while maintaining the integrity of your measurements with a ...
www.ni.com
Please let me know does this work for me? If so, send me a quotation for it
Also, is there any other options that could do the job?
Best Regards
Khaled
Best Regards
Khaled
Dr. Khaled Al-Aribe
Associate Professor
Department of Mechanical Engineering
College of Engineering
Abu Dhabi University
Email: khaled.alaribe@adu.ac.ae
Phone (cell): +971504290638
(1,003 Views)
Could you rephrase what you're trying to find out?
FYI - this is a forum where fellow NI product users discuss and help each other and we in no way represent NI. Maybe sometimes, someone from NI might address certain issues but not guaranteed, your request for a quote is not appropriate for the forum and you should contact NI sales.
In general, BNC-2120 is not compatible with USB-6003.
Santhosh
Soliton Technologies
(981 Views)
