Hello rsdgdf,
From the title of your post, it appears that you are using .NET to
program your DAQ device. If this is the case, there does not appear to
be a shipping example that does exactly what you want, but you can
modify the ContGenVoltageWfm_IntClk example relatively easily (located
at C:\Documents and Settings\All Users\Documents\National
Instruments\NI-DAQ\Examples\DotNET2.0\Analog Out\Generate
Voltage\ContGenVoltageWfm_IntClk).
You need to change is the type of reader to the type in your
subject and then pass it a 2D array. The first dimension is channels
and the second dimension is values. For example, writing 3 values to 2
channels would be:
d(0, 0) = 1
d(0, 1) = 2
d(0, 2) = 3
d(1, 0) = 1
d(1, 1) = 2
d(1, 2) = 3
Since most of our devices have dedicated DACs for each analog ouput
channel, then the outputs should be synchronized. I believe that the
writer will not work without hardware timing either, so that should not
be an issue.
I found a similar thread that may help you out as well, located here. There is not an example, but it shows more about exactly what to change where. Take a look and post back here if you have any questions.
Neal M.
Applications Engineering National Instruments www.ni.com/support
