I am a beginner to NI hardware. Thank you in advance for your time.
I am trying to generate a 1MHz square wave with the 6361 using DAQmx. I notice that when I change "samples to write" the frequency changes. and when I change "rate" the frequency also changes..
I was not able to generate a frequency of 1MHz without receiving an error
"onboard device memory underflow. .....
Reduce your sample rate or try using DMA or USB Bulk."
I am incorrect to understand that the 6361 is capable of generating 1MHz frequencies?
