Hello;
The best way to go about that is to completely uninstall Labview, shutdown your machine and remove the board.
Then, install only NI-DAQ on your machine. Shutdown the computer again, and put the hardware back in.
Run MAX and test the resources of your board. If everything is ok, install Labview, however, choose the custom installation and unselect NI-DAQ from the driver list.
You should be good to go after that.
Hope this helps.
Filipe A.
Applications Engineer
