Hi @mawad,
As far as I know, there's no way of using a differential AI as two single ended AIs, due to the circuitry (which makes it differential - see this White Paper http://www.ni.com/white-paper/3394/en/ ) which allows the input to be dealt with in a differential manner being inside the myRIO already.
What I would advise is to use a summing amplifier to create a voltage/level switcher. This can allow you shift your signal - so if your sensors output between -5V and 5V, you can shift the range of signals up to 0-10V, and then use an amplify to amplify the signal by half, so it is in the allowable range of the single ended Analog Input (0-5V).
The web pages below should help with this.
The Summing Amplifier
http://www.electronics-tutorials.ws/opamp/opamp_4.html
What analog circuit i should use to shifting a signal from -5..5v into 0..10v?
http://electronics.stackexchange.com/questions/225889/what-analog-circuit-i-should-use-to-shifting-a...
Hope this helps!
Amy
Amy K
Applications Engineer
National Instruments UK & Ireland
