Multifunction DAQ
出現錯誤 -200432
myTask.AOChannels.CreateCurrentChannel( _
physicalChannelComboBox.Text, _
"", _
Double.Parse(minimumValueTextBox.Text), _
Double.Parse(maximumValueTextBox.Text), _
AOCurrentUnits.Amps)
我輸入電流值但出現以下狀態
Selected physical channel does not support the output type required by the virtual channel you are creating.
Create a channel of an output type that is supported by the physical channel, or select a physical channel that supports the output type.
Property: NationalInstruments.DAQmx.AOChannel.OutputType
Requested Value: NationalInstruments.DAQmx.AOOutputType.Current
Possible Values: NationalInstruments.DAQmx.AOOutputType.Voltage
Task Name: _unnamedTask<0>
Status Code: -200432
如何解決??
(2,050 Views)
Accepted by qoo10223
您好,
請問連接的儀器是什麽?您的physical channel與您建立的channel的輸出類型不相符,因此才導致出現此錯誤訊息。
(1,942 Views)
