08-19-2016 07:21 AM
Hello
I have installed MS Visual Express 2013 and Measurement Studio 2015 for Visual Studio 2013.
When debugging my application the following error is there:
NationalInstruments.UI.WindowsForms.Slide is unlicensed
I modified the licenses.licx file with the following items:
NationalInstruments.UI.WindowsForms.PropertyEditor, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.Legend, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.LedArray, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.Tank, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.ToolStripPropertyEditor, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.InstrumentControlStrip, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.NumericEdit, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.NumericEditArray, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.Meter, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.Led, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.SwitchArray, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.WaveformGraph, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.ScatterGraph, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.Slide, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.ComplexGraph, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.Knob, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.Switch, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.DigitalWaveformGraph, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.Gauge, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
NationalInstruments.UI.WindowsForms.Thermometer, NationalInstruments.UI.WindowsForms, Version=8.9.35.246, Culture=neutral, PublicKeyToken=18cbae0f9955702a
And still the same error at the first line, when creating my first item with NI in the source.
I have spent hours meanwhile, can't find any help on the web how and what to modify
to make that thing work...
Has anybody had similiar problems and a usefull solution that make measurement studio work with ms visual studio?
thx
Andy
08-26-2016 02:05 AM
Hi there,
I only can advise you to have a look to the following links:
http://zone.ni.com/reference/en-XX/help/372636F-01/mstudiowebhelp/html/unlicenseddialog/
Or to contact your local NI branch if you have SSP.
Hope that is helping!
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
