12-10-2021 12:59 AM
Hello guys,
I'm currently trying to use the Tdms assembly in my .net 5. project, the problem is when i try to use the assembly i get following exception.
Is there actually a way to use the Tdms assembly in dot net 5 or are you guys also facing this issue?
I have already tried to add the System.Web assembly manually to my project but that doesn't make any difference.
With .Net Framework i'm not getting this exception.
12-14-2021 05:38 AM
Needed to recreate 9 Projects with .Net Framework to get it running.
I hope NI will add .net core support soon, as .net core released since 2016 now.
12-21-2021 04:08 AM
Hi.
I have similar issue when try to use NI network variable in .NET 6 based ASP.NET Core web application. This code is OK in the old .NET 4.8 framework.
BR,
Ilkka
01-11-2022 04:17 AM
Hey,
sorry for the late replay, but I think the easiest way to get it running, is using the .Net Framework, if that is not possible for yourproject, you might be able to create a little .Net Framework 4.8 console application that will be called by the .Net 6 Web Application and writes the Network Variables to an text file.
01-11-2022 06:09 AM
Hi, thank you for your reply. Our application runs in .NET 4.8 at the moment. That is no problem.
Yes, I can make a wrapper around .NET 6 incompatible stuff.
Or maybe NI Network variable can be replaced by gRPC:
We use DAQmx and other NI libraries in many projects so there is a long way until everything runs on .NET 6. 😉
BR, Ilkka
01-19-2022 04:14 AM
If all you are doing is reading TDMS files in .NET 6, I have a free and open-source library just for that: https://github.com/mettekou/FSharp.Data.Tdms#fsharpdatatdms-. While it is written in F#, it can be called from C# as if it were C# code. Alternatively, the free and open-source https://github.com/mikeobrien/TDMSReader targets .NET Standard 2.0 and will therefore work on .NET 5 and 6. Support for reading DAQmx data or writing TDMS files is not in either library yet, but if you have a need for it, please create an issue on the respective GitHub pages and I will have a look.
01-19-2022 08:30 AM
Thank you, that's good to know. Actually I need to write data to TDMS files. But I managed to use the NI TDMS dll, as I converted my projects to .Net Framework.
