Using NationalInstruments.Tdms in .net 5?
Hello guys,
I'm currently trying to use the Tdms assembly in my .net 5. project, the problem is when i try to use the assembly i get following exception.
Is there actually a way to use the Tdms assembly in dot net 5 or are you guys also facing this issue?
I have already tried to add the System.Web assembly manually to my project but that doesn't make any difference.
With .Net Framework i'm not getting this exception.
(878 Views)
Needed to recreate 9 Projects with .Net Framework to get it running.
I hope NI will add .net core support soon, as .net core released since 2016 now.
(839 Views)
Hi.
I have similar issue when try to use NI network variable in .NET 6 based ASP.NET Core web application. This code is OK in the old .NET 4.8 framework.
BR,
Ilkka
(789 Views)
Hey,
sorry for the late replay, but I think the easiest way to get it running, is using the .Net Framework, if that is not possible for yourproject, you might be able to create a little .Net Framework 4.8 console application that will be called by the .Net 6 Web Application and writes the Network Variables to an text file.
(729 Views)
Hi, thank you for your reply. Our application runs in .NET 4.8 at the moment. That is no problem.
Yes, I can make a wrapper around .NET 6 incompatible stuff.
Or maybe NI Network variable can be replaced by gRPC:
https://grpc.io/
We use DAQmx and other NI libraries in many projects so there is a long way until everything runs on .NET 6. 😉
BR, Ilkka
(723 Views)
If all you are doing is reading TDMS files in .NET 6, I have a free and open-source library just for that: https://github.com/mettekou/FSharp.Data.Tdms#fsharpdatatdms-. While it is written in F#, it can be called from C# as if it were C# code. Alternatively, the free and open-source https://github.com/mikeobrien/TDMSReader targets .NET Standard 2.0 and will therefore work on .NET 5 and 6. Support for reading DAQmx data or writing TDMS files is not in either library yet, but if you have a need for it, please create an issue on the respective GitHub pages and I will have a look.
(671 Views)
Thank you, that's good to know. Actually I need to write data to TDMS files. But I managed to use the NI TDMS dll, as I converted my projects to .Net Framework.
(651 Views)
