Ni-DAQmx .NET6 Support
Hi
As we all know, Microsoft announces the new version of .NET which is the .NET6.
Now currently if you wish to work with C#, you have to opt to at maximum .net 4.8 framework.
Is there any plans to support these new versions of .NET? As i wish to upgrade my systems and start working with the latest version of .NET.
(924 Views)
I think Yes, but I am not sure for this.
You may send an email to NI to obtain the right information for this, you will follow the news to know the upcoming releases.
(872 Views)
Hi, I ported an old .NET4.8 Windows Forms application into .NET6 by using .NET upgrade assistant from Microsoft.
The application can be compiled and run. It works as long as no NI UI controls are called. Those result the following error:
Maybe there is some hope, that NI will bring Measurement Studio into .NET6 because I succeeded to port a non-NI based old .NET4.8 windows forms application into .NET6.
I did not test DAQmx..
BR,
Ilkka
(807 Views)
I second that. It was quite ok to ignore .NET5 because this was a work in progress version with many problems and missing features.
But .NET6 is a LTS version that is here to stay and Microsoft, despite telling that Framework 4.8 will be supported for a long time, is doing everything to pull developers to .NET6. I mean they even adapted Windows Forms, modernized it by a lot and try to convince developers to convert their older projects.
This tells me that Microsoft wants to get rid of .NET Framework as early as possible. NI has to move to support developers in this transition and not to thwart them.
(788 Views)
Dear <Name Redacted>,Thank you for your patience, I got a reply from the product planning team.We do not plan to support .NET Core in application software or driver software in 2022. We are reviewing plans for 2023, but those are definitely not yet solidified.I hope this helps, I will go ahead and mark this technical support case as "potentially resolved". Feel free to let me know if you have any follow-up queries regarding this topic!Regards,<Name Redacted>NITechnical Support Engineeringwww.ni.com/support
Regarding sending an e-mail to NI: this is the reply I received from NI when inquiring about support for .NET 6 across their product lines in December of last year.
(668 Views)
Thanks. This is after all a clear statement, albeit a quite frustrating one.
For me, it would be ok to end development of Measurement Studio alltogether and focus on the .NET drivers for each device category alone.
Drivers like NI-DCPower always lagged behind NI-DAQmx.
(626 Views)
