Dear forum,
I am again somewhat perplexed by the NI-DAQmx merge module. I am currently developing with NI-DAQmx version 15.1.1f1 and I try to package my program with the necessary NI modules. It references two NI .NET modules: DAQmx, version 15.1.45.61, and Common, version 15.0.40.49154. So what merge modules do I need to use?
The merge module MStudioDAQmx.2012.msm contains the correct version of the DAQmx DLL: 15.1.45.61, but what MStudioCommon... merge module is the correct one? The ModuleDependency table of the module MStudioDAQmx.2012.msm lists a module with the id "Module_Id_Common_2012_32", the language 1033 and the required version "15.0.40.49154".
I have two options:
.) MStudioCommon.2012.msm has the id "MStudioCommon.2012.1C9B2EB5_9E34_4944_BA92_B30CCA4E9205", language 0 and version "13.0.0.190", so this merge module does not seem to be the one I am looking for. If I use this merge module I get the warning
"Severity Code Description Project File Line Suppression State
Warning ICE25: Possible dependency failure as we do not find Module_Id_Common_2012_32@1033 v15.0.40.49154 in ModuleSignature table RadioactiveDecay.Setup light.exe 0"
and the MSI file seems to contain the wrong version of the necessary files: 13.....
.) MStudioCommon.2010.msm has the id "MStudioCommon.2010.039160C5A7A24C49AD122694436A47BB", the language 1033 and the version 15.0.0.0. This might be the merge module I am looking for. If I try to use this merge module I get the error
Error Unable to open merge module 'C:\Program Files (x86)\Common Files\Merge Modules\MStudioCommon.2010.msm'. Check to make sure the module language is correct. 'The language of this installation package is not supported by your system. (Exception from HRESULT: 0x80070657)' "
So which merge module actually contains version 15.0.40.49154 of the NationalInstruments.Common.Dll? Which is the correct one? A few years ago I used the 2012 version of both merge modules, but something seems to have changed.
Best regards & thanks in advance
Stephan
