From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Licence Problem with Measurement Studio and Visual Basic 2008 Express
Hello!
I have a licence for the professional edition of measurement studio 8.5 and I use the express edition of Visual Basic 2008.
I'm trying to use the FFTfunction but get the exception {"NationalInstruments.Restricted.AnalysisLicenser is unlicensed."}
Does anyone have an idea?
Thanks in advance!
Andreas
Here's the complete error message:
System.TypeInitializationException wurde nicht behandelt.
  Message="Der Typeninitialisierer für "NationalInstruments.Analysis.Dsp.Transforms" hat eine Ausnahme verursacht."
  Source="NationalInstruments.Analysis.Professional"
  TypeName="NationalInstruments.Analysis.Dsp.Transforms"
  StackTrace:
       bei NationalInstruments.Analysis.Dsp.Transforms.RealFft(Double[] realData)
       bei LDS.LDS_Form1.ButtonFFT_Click(Object sender, EventArgs e) in D:\devel\LDS\pc\LDS\LDS\LDS_Form1.vb:Zeile 1700.
       bei System.Windows.Forms.Control.OnClick(EventArgs e)
       bei System.Windows.Forms.Button.OnClick(EventArgs e)
       bei System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
       bei System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       bei System.Windows.Forms.Control.WndProc(Message& m)
       bei System.Windows.Forms.ButtonBase.WndProc(Message& m)
       bei System.Windows.Forms.Button.WndProc(Message& m)
       bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       bei System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
       bei System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
       bei System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
       bei System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
       bei System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
       bei System.Windows.Forms.Application.Run(ApplicationContext context)
       bei Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
       bei Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
       bei Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
       bei LDS.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:Zeile 81.
       bei System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
       bei System.AppDomain.nExecuteAssembly(Assembly assembly, String[] args)
       bei System.Runtime.Hosting.ManifestRunner.Run(Boolean checkAptModel)
       bei System.Runtime.Hosting.ManifestRunner.ExecuteAsAssembly()
       bei System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext, String[] activationCustomData)
       bei System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext)
       bei System.Activator.CreateInstance(ActivationContext activationContext)
       bei Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssemblyDebugInZone()
       bei System.Threading.ThreadHelper.ThreadStart_Context(Object state)
       bei System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       bei System.Threading.ThreadHelper.ThreadStart()
  InnerException: System.ComponentModel.LicenseException
       Message="NationalInstruments.Restricted.AnalysisLicenser is unlicensed."
       Source="NationalInstruments.Common"
       StackTrace:
            bei NationalInstruments.Restricted.LicenseBase.ShowUnLicensedBehavior(Type type, Object instance)
            bei NationalInstruments.Restricted.LicenseBase.a(Type A_0, Object A_1, String A_2)
            bei NationalInstruments.Restricted.LicenseBase.a(Type A_0, Object A_1)
            bei NationalInstruments.Restricted.LicenseBase.RunTimeCheck(LicenseContext context, Type type, Object instance)
            bei NationalInstruments.Restricted.LicenseProviderBase.GetLicense(LicenseContext context, Type type, Object instance, Boolean allowExceptions)
            bei System.ComponentModel.LicenseManager.ValidateInternalRecursive(LicenseContext context, Type type, Object instance, Boolean allowExceptions, License& license, String& licenseKey)
            bei System.ComponentModel.LicenseManager.ValidateInternal(Type type, Object instance, Boolean allowExceptions, License& license)
            bei System.ComponentModel.LicenseManager.Validate(Type type, Object instance)
            bei NationalInstruments.Restricted.AnalysisLicenser..ctor()
            bei NationalInstruments.Analysis.Dsp.Transforms..cctor()
       InnerException:
(5,187 Views)
Accepted by topic author tyketyke
Hi Andreas,
This is expected for any Visual Studio express edition because those editions don't allow 3rd party integration. Thus you need to perform a few extra steps to get licensing to work properly.  Refer to the Measurement Studio Support for Visual Studio Express Editions KB (in  particular, the 2nd paragraph which points you to our help).
Best Regards,
Jonathan N.
(5,183 Views)
This worked!
Thanks!
Andreas
(5,168 Views)
Getting back into DAQ after some time off and am having a similar problem.
I am using Visual Studio 2008 Pro and installed Visual Studio 8.1.2 Enterprise.  I know these versions don't  integrate  (don't know if I even saw the option during installation) so I added the licx file to my project as many of the help files say to.
Simple C# Winforms test app with one control on one form.  Debug and get the "unlicensed assembly" error.  I've re-read the article
Using Measurement Studio 8.1.2 with Microsoft Visual Studio 2008 several times but still no luck.
What can I try next?  I was surprised it never asked for my serial number during installation.
Thank You all.
(3,414 Views)
