How to improve the speed of multi curve drawing
Deer All:
            I want to draw multiple curves on a graph. The number of curves is a variable. So I adopted the method of list < point > assignment. This method is time-consuming when the amount of data is large.
Graph.Data[Chn++] = List<Point> ;
(1,272 Views)
Accepted by shmily0923
Assigning each data item individually is probably causing the graph to do some redundant re-processing as each item is assigned.
You can inform the graph about multiple updates by using the standard WPF BeginInit/EndInit methods:
Graph.BeginInit();
/* your existing code:
... Graph.Data[Chn++] = List<Point> ; ...
Graph.EndInit();
Or you could assign all of the data to the graph at once:
var allChannelData = new List<List<Point>>();
/* your existing code, using new collection:
... allChannelData.Add( List<Point> ); ...
graph.Data.AddRange( allChannelData );
// or alternatively, graph.DataSource = allChannelData;
I would also suggest comparing your graph configuration with the recommendations in the "Optimizing the WPF Graphs" help topic.
~ Paul H
(1,233 Views)
Thank you very much. The method of using addrange speeds up a lot.
(1,220 Views)
