02-26-2008 12:43 PM
02-27-2008 12:14 PM
03-07-2008 09:43 AM
Hello
I've got following answer:
"Thank you for contacting Motic
Instruments.
If DirectShow supports TWAIN drivers then
this camera would be compatible otherwise it can only be used on the Motic
program."
So what now ?
Thanks for help
03-07-2008 06:09 PM
03-08-2008 08:25 AM
03-08-2008 09:32 PM
03-18-2008 09:52 PM
08-11-2014 05:44 PM - edited 08-11-2014 05:45 PM
Is this still true?
http://www.motic.com/upload/File/new_moticam_booklet_EN.pdf
I found one of your motic brochures that claims moticam 2 & 3 are direct show compliant
These are high resolution.
However, while I can find the TWAIN driver, I cannot find the Direct show
12-15-2014 01:25 PM
I've tested the Moticam 2 with Window 7. The camera appears as an imaging device under device drivers but will NOT appear in DirectShow driven apps like AMCap. Boo har. We need the OS to recognize the cam directly for use in a kiosk application driven by Flash.
