From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Machine Vision
how can i read a *.bmp picture into labview
i'm using labview 5.1 and i already have the picture in a bmp format-all i need is processing it.
best regards,
Ofer Kadar
(4,053 Views)
To open a *.bmp file in LabVIEW, use "Read BMP File.vi", which is located in the diagram Function palette -> Graphics and Sound -> Graphics Formats. To view the *.bmp, the best way is using the Draw Flattened Pixmap.vi" located in Function palette -> Graphics and Sound -> Picture Functions. Create an indicator for the "New Picture" output.
If you have IMAQ, you can use "IMAQ Read File.vi", which is located in Function palette -> IMAQ Vision -> Files. To see the image, use IMAQ WindDraw, located in Function palette -> IMAQ Vision -> Display (basics) (You should allocate the necessary memory for the image using "IMAQ Create.vi". This vi is located in Function palette -> IMAQ Vision -> Management)
Good luck!
www.vartortech.com
(4,053 Views)
