06-25-2016 09:13 AM
06-27-2016 07:32 AM
Hi Jorge,
Can you provide us with the code you try to use ?
Do you have any error showing up when the program hangs ?
06-27-2016 07:45 AM
Hello Maxime,
After having this situation I made a fast modification to one example that you can find in attach. It's simply multiplied N times in parallel.
The function doesn't return error. It hangs and If I highlight in the control panel I can see that it's waiting for one "ocr read text" function to complete.
Br,
Jorge Amaral
06-27-2016 07:45 AM
Hello Maxime,
Br,
Jorge Amaral
06-27-2016 09:01 AM
One update,
If I reduce the delay to zero and I remove the ROI forcing to search the complete image crashes the aplication.
This is not the situation that I have on my client but shows that something it's not right.
Br,
Jorge
