Can someone offer me some advice on pattern matching, and whether I am going about the right way of doing it?
I've been asked to modify a piece of test equipment to detect a new addition to the parts that the equipment is used to identify. Due to the fact that these new parts are entirely different to the old parts I can't use the old identification technique that someone wote (about 10 years ago).
In the attached zip file are typical images of the parts that I need to detect (Data\Template Images and Data\Example Images). Unfortunately I can't do much with the images or lighting at the moment. This is a dedicated piece of test equipment that is currently in use and I can't go changing anything hardware related because it will break the current process. I can change the camera settings in max because they can reversed easily.
It may or may not be the best technique, but I've attempted a pattern match technique that extracts a relevant portion of the image (either the text or the circles) and compares it against a series of templates and identifies the highest scoring template. (Pattern match against image IMAQdx.vi in the project).
It kind of works..... but it's not bullet proof.
Here is what I have found, and issues I am struggling with:
1) Running a templates as a source image against the other template images returns more than one match (I'd prefer it to be a singular match) or an incorrect match entirely.
2) As with the template images, running various production pieces through yields incorrect matches from time to time.
3) Part to part variation in the image captured is quite high (see Example Images folder). These images are of the same type of part and are typical of what will be passed through the test equioment. This is due to the machining finish and finishing process applied to the part. There isn't a lot I can do with this unfortuantely.
I guess my first question is: am I going in the right direction with pattern matching, or is there a better way of doing this?
Assuming I am going in the right direction, what can I do to captured image/ template image to post process it to improve identification? I'm aware of various processes and filters etc that can be applied, but don't have enough experience to know what to do to give the pattern matching a good chance of success.
Andy
