Lookout
Upgrading from Lookout 6.2 to 6.5
If I upgrade my Lookout server from 6.2 to 6.5 which is also the same machine my Web Player files folder is located, will clients still running the 6.2 Web Player be able to run the new 6.5 process file from my Web Player folder on the server?
Jason Phillips
(6,665 Views)
No. If the process file is 6.5, you need to install the 6.5 web player on client.
Ryan Shi
(6,643 Views)
If I leave the folder (named 'scada') on the server that contains the files needed for the clients to access my process through the 6.2 web player, and then install 6.5 and create a new folder (name 'jpscada') for the 6.5 web player files, will the clients running 6.2 web player be able to view process through the 'scada' folder and the 6.5 clients running 6.5 web player be able to view process through the 'jpscada' folder?
Jason Phillips
(6,638 Views)
Accepted by topic author JPhillips
Yes.
Ryan Shi
(6,624 Views)
Thanks!
Jason Phillips
(6,617 Views)
