03-12-2007 09:43 AM
03-13-2007 08:26 PM
03-14-2007 09:13 AM
Ryan:
I took out all reference on the Time Syn on the Client and the other server. All had 6 hours in advance. Shut down client and 1 server. Only main server running. I rebooted and still was 6 hours off in user manager. Correct time was 8:44 am and after reboot with one server running user manager showed 14:44. We do get an error message when we reboot. It is "At least one service or driver failed during system startup. Use event viewer to examine the event log for details". Also when I pull up user manager I have pressed help and does not respond. Not for sure whether that has to do with anything. Thanking you in advance for your help.
Carl
03-14-2007 11:29 AM
Did a MS Query in excel and looked in table "RawData" found "LocalTime" and "LoggingTime" in this table. Below is what I found. Where does LoggingTime get its data from.
LocalTime | LoggingTime |
3/1/2007 13:28 | 3/1/2007 19:28 |
Carl
03-15-2007 01:26 AM
03-16-2007 08:20 AM
On 2-1-07 I was trying to get the computer to sign off operators after 1 minute of inactivity. I posted message on NI site. During that time I took out all references to Time Synchronization and it started working correctly. I did not think of it anymore until I went to that Server and noticed that the operator that had worked the night before was still signed on.
I took out all references to Time Synchronization on the Client and the other Server. Still did not put correct time in user manager. Turned off all machines and then rebooted primary server and user manager had incorrect time for my log on. That is when I received the error message.
WinMgmt-“WMIADAP was unable to process the remote/access performance library due to a time violation in the open function”.
MSSQL$BKUPEXEC-“SuperSocket info:SpnRegister Error 1355”
MSSQL$8KUPEXEC-“SuperSocket info(SpnRegister):Error 1355”
MSSQL$MICROSOFTBC-“The description for EventID(1901) in source(MSSQL$MICROSOFTBCM) cannot be found. The local computer may not have the necessary registry information of message DLL files to display messages from a remote computer. The following information is part of the event (SpnRegister):Error 1355”.
NI Programs in Services window
Citadel, Doman Service, Lookout 6.0, PSP Server, Time Synchronization.
Other Programs in Windows Task Manager
Llssrv.exe, lkcitdl.exe, lkads.exe, lktsrv.exe, nicitdl5.exe-not sure all are NI programs.
I have a Lookout 6.0 evaluation copy on my home computer. I looked this morning and there is a 6 hour difference in my computer at home.
Again thanks for any help you can give me.
Carl
03-19-2007 02:58 AM
03-19-2007 10:22 AM
We had 5.1 lookout installed and then we upgraded to 6.0.2. The guy that installed lookout 6.0.2 had some kind of unistall program from NI to do this. Do I need that program from you folks?
Carl
03-19-2007 09:19 PM
