01-31-2006 04:20 AM
01-31-2006 11:08 AM
02-01-2006 01:13 AM
Hello Mert,
thank you for your quick reply.
The message appears in fact when I build the distribution kit, not when I select DAQmx in the "Driver&Components" menu.
I followed your instructions on "WriteDigChan" example.
Attached you find the zipped log file and the .cds file (I don't know if something is corrupted on this file).
02-02-2006 12:24 PM - edited 02-02-2006 12:24 PM
Message Edited by Mert A. on 02-02-2006 12:25 PM
Message Edited by Mert A. on 02-02-2006 12:26 PM
02-14-2006 01:53 AM
Hi Mert!
I was ouside office for one week so I did't try your suggestion till today.
Following your instruction I tried to install .NET Framework 1.1, but did't work because the installer told me "Microsoft .NET Framework 1.1 is not present" and could not continue.
Then I used MSIBlast program to remove NI Measurement Studio for VS2003.
After uninstall, I created the distribution of "WriteDigChan" example successfully!
(After that, I tried again to re-run the NI Driver installation of .NET, still without success. However now the problem is fixed)
Thanks a lot!
02-14-2006 10:21 AM
