LabWindows/CVI
Using 3rd party dll, I have lib file but no h file, is there a way around it??
Do I Definitely need the *.h file???
(2,666 Views)
Check out the following KnowledgeBase which gives ideas on how to call the DLL functions if you know the prototypes. Also the document gives you suggestions on how to use third party programs to access the functions prototypes if you do not already know them.
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(2,660 Views)
