01-06-2012 05:25 AM
I am working on the IR images received through a TCP/IP client application. Once the image is received, I need to produce the histogram of the selected area. Also, when I use say a line tool to produce ROI, I need to retain the ROI produced by the previous ROI tool (ROI on the image only). While I am able to produce histogram of current ROI, I loose the earlier ROI. So, how can I retain the earlier ROI (in the current session only)?
01-06-2012 05:43 AM
Could you possible define your question more precisely to make it more evident where the problem with CVI is? For example, what is a current session, why can't you save the ROI, etc.?
01-08-2012 11:59 PM
Thank you very much for the response.
Actually, when the image is reproduced in the Lab View, I need to produce the histogram of the selected area. To select the area of interest, I am using various ROI tools. Now, when I use say a line ROI tool to produce ROI, I need to retain the ROI produced by the say, rectangle ROI tool. That is, I am using multiple ROI tools to select the various ROIs on the image and every time when I use new ROI tool, the ROI selected by the previous tool must be retained.
01-09-2012 12:29 AM
obviously you confused LabVIEW with LabWindows This one is the forum for LabWindows, and certainly you will get the appropriate support in the LabVIEW forum...
01-09-2012 06:06 AM
continued here
01-10-2012 12:16 AM
Yes, I was and I have poseted the doubt in the LabVIEW forum. Thank you.
