LabWindows/CVI
How to Map Defect Sticker. Please help me! (Inspection)
Now I'm doing the inspection. I want to find defects in this sticker. When it is not perfect, I want to find those defects using a Geometric algorithm. I am currently using the NI Vision Builder AI 2020 program. What settings do I need to set? Or what should I do? Please help me. Or do I have to ask on which board? I'm very new to this task.
(865 Views)
Two notes:
1. Images are no visible, at least on my side
2. I see you have tagged LabVIEW: this may be a problem, since you happened to land on the board dedicated to LabWindows/CVI, which is a completely different development environment. If you are actually using LabVIEW you should repost this in the proper board or you may want to post directly to the Machine Vision forum board where you may have better assistance
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(802 Views)
