01-03-2006 03:51 AM
01-03-2006 12:06 PM
01-04-2006 04:46 AM
Thank you Mert for your comments !
We first cleared the distribution kit entries in the prj-file and tried to make distribution kit with only the executable (and uir). Then we did what you asked (logfile attached).
We see that the logfile shows an error finding NIMdf.dll . This file is present on our system, perhaps CVI has a problem finding it ?
01-04-2006 04:58 AM
Mert,
We placed NIMdf.dll in c:\winnt\system32 and now it was found. But still the message 'unknown error' appears when trying to make a distr. kit. Now the problems seems to be linked to the NI-4070 DMM. We will try to reinstall the software for it and see whether that helps.
01-04-2006 05:25 AM - edited 01-04-2006 05:25 AM
Is there a clue there? C:\winnt ? I thought CVI 8.0 was not supported on the NT platform? (Or are you using Win2K?)
JR
Message Edited by jr_2005 on 01-04-2006 11:28 AM
01-04-2006 05:31 AM
01-04-2006 11:46 AM
01-05-2006 01:55 AM
Hallo Mert,
Just did as you told, included the realtime stuf and tried again with similar results. Unknown error.
The difference is that now I don't get the logfile.
I did find a file, created at the time of the error, MSIa233.log containing:
"You have a higher version on the system. Please uninstall that version before trying to install this version."
Co ( working with Han on this problem )
01-05-2006 10:54 AM
Product 'NI-DMM 2.4.6' depends on a product that cannot be found on the system.If you check the directory Program Files\National Instruments\Shared\MDF\Manifests\, you should notice the file named NI-PAL for Phar Lap ETS {...}.xml is missing. This is because a new enough version of this support driver is not installed. Forcing an install of the RT features from your DAQmx installer should solve this.
ID of missing product: 'NI-PAL 1.8.2f0 for Phar Lap ETS' - {981ECDC9-F27F-4E40-BCC8-AD7658866338}
01-06-2006 01:18 AM
