01-20-2012 05:20 AM
Can any one say, Why Generate Control Callback is disabled ?
Thank you
AD
01-20-2012 05:42 AM - edited 01-20-2012 05:47 AM
Normally it happens when you have not specified a callback for the control:
01-20-2012 05:43 AM - edited 01-20-2012 05:44 AM
all I can add is that the entry 'Generate Control Callback' is dimmed if more than one control has been selected. Sometimes this happens by accident...
01-20-2012 05:51 AM
I have selected default events. EVENT_COMMIT, EVENT_RIGHT_CLICK
01-20-2012 06:10 AM
This is done in Code >> Preferences >> Default Events... menu function, but the editor does not automatically create control callbacks: you must manually set the callback for each and only the controls you want a function assigned to; this is done in the properties panels for each control.
