09-08-2008 11:29 AM
Hi all...I am trying to using a quadrature encoder with A,B,Z outputs on an e-series card (pci-6052e). the problem is that the card does not support the z output since it only has 2 counters. So i am trying to find a way to get around this problem. I start off using ctr 1 (to the source pin of which i connect the A signal)..to count the events which will tell me how many angles the shaft has rotated through. The only other thing i need is to use the single pulse generated on the z line to reset the count each time it turns high. From reading posts it seems like i have to stop and restart the counter task to accomplish this. So the thing i dont know how to do is to convert that pulse on the z-line to a boolean value so i can run a case loop to stop and restart the task. I can use a daq-mx start trigger to look at the pulse but how do i convert that to a boolean value to run the case loop.
Thanks in advance, Shyam.
09-08-2008 01:00 PM
Hi again..I am attaching a picture of the code in lv..the thing i want to do is to link the trigger output somehow to the case loop..!
Thanks, Shyam.
09-09-2008 05:38 PM
Hi Shyam,
Depending on how fast the encoder will be rotating, you can do a few things. The simplist is to just read the Z index on a digital line as you have begun doing. Using a DAQmx Read, you can detect the state of the line and if the rotation is slow enough, you can use the boolean value. Again, this is not ideal. The newer M-Series boards have a counter input for the Z index in addition to being able to do change detection on digital lines which will make this task much easier. See if this works for your needs.
Kent
