I cannot reproduce your slowdown (LabVIEW 8.2.1), but your code deserves a few improvments.
Basically, whatever you are doing makes no sense. With each iteration, you get several hundred (100-600) new points that you append to the array in the shift register, but then you throw everything away except element 0 and elements 50+. This constant resizing of arrays can be very inefficient because of memory reallocations.
Is it possible that you want to take a running average of the last 50 points for each simulation path. In this case you want to only get a single point from each simulator call and then you would just use "replace array subset" and replace the element at index j, where j is the remainder of using "Quotient&Rmainder of [i] divided by 50. The element order does not matter, right? (You can also get rid of all these shift registers entirely and use the express VI "Collector" with the history set to 50.)
You code parts are fighting each other. You try to simulate acquisition timing (different for each simulator!) but at the same time you place them all in the same loop and are enforcing timing with the timed loop.
It is a bad idea to use an LED as a control. LEDs are indicators! Most likely, you should also set the meachnical action to "latch when released", else you'll not be able to return to the main program for long because the subVI will pop up again at the next iteration, over and over!.
Another problem is the fact that the main timed loop stalls until the subVI is closed. Why even use a timed loop then? Why do you think you need a subVI to change a few controls?
These are all typical beginner problems. Maybe you should do a few tutorials and browse the shipping examples first. 😉
